Oil Cooler Help Needed
Ready2Bite
Windsor, Ontario
Went to instal the new oil cooler lines last night and 3 out of 4 fittings torqued correctly - 4th has stripped the hole in the cooler. Where to get a new oil cooler? Not sure there is any way to fix this one. I was more than a little pizzed but - what do you do.
so where can I get a new oil cooler?
a new cooler from either the dealership or one of our vendors.
if the threads are stripped out, possible Heli-coil repair???
Do you happen to know what size wrench fits the larger nuts on the lines? I was going to do mine and realized I don't have anything large enough in an open end wrench.
