Oil Cooler Line Fittings
Discussion in 'General Discussion' started by 68charger, Feb 9, 2019.
  1. 68charger
    68charger Member Supporting Member
    305
    Jan 1, 2010
    alberta ca.
    Hi all, can anyone hear tell me what fittings i need to make up my own cooler lines, specifically the size and type fittings that go into the block. Thanks
  2. rottenronnie
    2,600
    50
    Jul 4, 2006
    Calgary, Alberta
    I took mine into an Industrial Hose place and had them made.
    They are now good for 3750 psi, which should be enough.
  3. 68charger
    305
    Jan 1, 2010
    alberta ca.
    i have access to a crimper at work, i just don't remember the type and size of fitting that goes into the block and cooler such as 10 or 12 ORB to JIC. I need some for a project so the length of the lines will be different then stock.
  4. Slitherbeast
    Slitherbeast Active Member Supporting Member
    2,253
    7
    Sep 10, 2007
    Alberta
    you are speaking of the OIL cooler lines? I have a set of life time oil cooler lines that leaked that I havn't returned .... the fittings are attached. you can get the correct sizing from them. Are you near Edmonton anytime soon? I can meet you somewhere :)
  5. GSJake
    GSJake Member
    76
    4
    Feb 13, 2018
    Care to tell us what company you bought them from as to avoid.
    Thank you.
    Jake
  6. SRT2SLOW
    4,367
    14
    Mar 27, 2010
    Green Cove Springs, FL
    Its a 12orb i believe. I have a few spare. I will double check when i get home
  7. 68charger
    305
    Jan 1, 2010
    alberta ca.
    Thanks Norbert, i'm not sure when i will be in next but i will let you know
  8. 68charger
    305
    Jan 1, 2010
    alberta ca.
    Thanks 2slow
  9. SRT2SLOW
    4,367
    14
    Mar 27, 2010
  10. 68charger
    305
    Jan 1, 2010
    alberta ca.
    and its 10 orb in both the block and cooler right?
  11. SRT2SLOW
    4,367
    14
    Mar 27, 2010
    Yes
  12. Slitherbeast
    2,253
    7
    Sep 10, 2007
    Alberta
    These were the ORIGINAL lines supplied by JSTVP. He has replaced them with perfect ones! The originals were a bad batch. Get Tony's and you can never go wrong! He is good people! :)
    GSJake likes this.
  13. walenator
    walenator Full Access Member
    1,497
    Jul 11, 2006
    Gainesville, Ga.
    I purchased Tony's. Never had a problems since.
