Cablefed
Mine are leaking just like everyone elses. I could take it to the dealer and have it covered under warranty and have it happen again and again. I don't like doing stuff over and over if I know it can be fixxed another way. I was looking at the current cooler and its a simple setup. There are two coolant lines and two oil lines.
My first option is to order an aftermarket oil cooler and mount it in front of the radiator. My thoughts were to delete the stock oil cooler all together. I plan on taking the coolant line that comes from the heater coil to the oil cooler setup and bypassing the cooler and going right back to the block from the heater coil.
My other option was to just have new AN lines made up to use the stock cooler. The new lines would be easier but I wonder if the aftermarket cooler will net me cooler oil temps since the cooler would now be in the direct path of airflow coming off the front of the truck.
Either way it looks like an easy afternoon job while performing an oil change. What are your thoughts aftermarket cooler or new AN lines? Thanks all!
