Kevan
Hey folks.
So, I'm changing the oil in the truck. Empty the pan, then pull off the filter (what a mess....).
I plug the pan back up and, pre-fill the new Mopar oil filter with some oil (as per Chuck's suggestion), lube the seal ring, and screw the filter back into place (just past hand-tight).
I refill the engine with some tasty new Mobil 1. Check level....check again....then start truck.
SPLOOSH!
Oil is coming out like a sprinkler from the oil filter! It's a horror show. I quickly shut off the truck and check the filter again. It's still got a little movement, so I break out the oil filter wrench and give it another 1/2 turn.
That should do it.
Rip to WalMart for another 6 qts. of Mobil 1 (I had some spares here). Come back home. Re-fill and check level again. I start the truck....
SPLOOSH!
I now have over 16 quarts of oil all over the garage floor (I'm so pissed).
I pull the filter off again to find out WTF is going on. As I'm unscrewing it, I see the problem:
TWO SEAL RINGS!!!!
Apparently the 2nd one didn't come off with the old filter. I've done a dozen changes in the truck and never had this happen. Oh well. At least I know it's not something major.
Unfortunately, when I pulled the filter off the 2nd time, both rings came off too. I have no idea which one is the old NAPA seal ring, and which one is the new Mopar seal ring.
One is square.
The other is trapezoidal shaped (not-square).
If anyone has a Mopar oil filter handy, could you check the shape of the seal ring and let me know how it's seated in there.
THANKS!
SPLOOSH!
That should do it.
SPLOOSH!
TWO SEAL RINGS!!!!
One is square.
THANKS!
