??? Never heard of that.White viper one.
I have always had to put 11-11.5 quarts in my motor with a complete oil and filter change. I just changed it rt now and took exactly 11.5 quarts to reach the top of the full line. Is it possible the previous owner put in a different oil level stick? Can someone give me the part number on your fill stick. Mine has one, I wanna see if they match up. Thanks
ATF in both trannys![]()
Well I can tell you that the pan looks just like and is the same size as the extra oil pan I have that I got off an extra viper motor I had. Only other explanation would be wrong oil level stick. Geez hope it's not that cause that would mean that I've been running more oil that I should for past five years. LolMost likely someone added an increased capacity pan. I know of one that adds 2.5 qts to the 8.5.
That pan fits our trucks?? Do tell, link?
Sorry I thought you meant oil pan not trans pan, my bad.............
Thanks! I'll check once I get home to see if it matches. I guess I better hold onto that extra pan. Mine has two holes in it for oil return from turbos.Hey bud, the 06 Dipstick should be 5037612AC. It shows to be available, but ironically the 05 is no longer!! Here's the other kicker. The 06 Pan shows no longer available, yet the 05 is still at the tune of $1100. Both pickups are available.
$1100 for an oil pan??? Me thinks MOPAR hates it's own. The very ones that support them are the ones getting shafted. I assume these are 1st run production not something new. :dontknow: If so were they $1100 in the beginning? :dontknow: Do the new Viper oil pans cost $1100? :dontknow: I guess a good question is do pans for Stangs and Vets cost $1100? :dontknow:
