Once more unto the breach go I
Ironhead
h-town
well its begun ,i got the truck backed into the garage, that was no easy task ,next weekend i start the tear down ,,took me two days of limping around trying to clear a spot but i did it !
you gonna do some engine bay painting while you got the valve cover off:D
good luck :rock: :burnout: :rock: :burnout: :rock: :burnout:
We should have a party James since I have some stuff to put back togther in the engine compartment too.
here is plan ,,,got all parts in house ,,health is improving rapidly,confidence is high ,we are go for take off :stupido2:
list once again,, i will check them off as i go ,,,i will try to take pics too as i go ,but some times i get tunnel vision on a project ,and my savantizim kicks and my eyes roll up into my head as i work ,, so be nice :eek:
#1 teardown and remove camshaft
#2 install comp cam 270
#3 install ported and polished heads (Thanks to Bone & his Crew)
#4 install new comp cam lifters & hardened puhrods
#5 install justin powdercoated intake,that was gasket matched , (Thanks 4 the extra polishing on ports Justin u da MAN)
#6 Install a bit of giggle jucie (just a bit)
#7 Install new SPEC clutch and viper master upgrade (thanks Blaine)
#8 Install stinkers new hood :slug:
DevilDawg3097 said:
It can be done in frame:D :marchmellow:
ok what exactly can be done ???what am i looking at other than a paint pen
I got all the faith in the world in you Big Boy. You will be kicking ass in no time, glad to hear your foot is a little better.:rock: :rock: :rock: :rock:
no I was told a rebuild could not be done in frame, well myth busted almost done. But if your like me and have no access to a hoist or engine stand it can be done inframe..
GriffsSRT said:
Good luck! Should look good.
look good???? ,, lil brother i aint goin for looking good im going to outrun u and jack lol in P.C.:burnout:
gotcha :rock:damn your givin me forged ideas now stop it !but how hard is it to drop the oil pan inframe????
Who you gonna hire to drive for ya' !!:D :D :D :D
Pretty simple actually loosen the the side engine bolt then put a bottle jack under ac and up you go about 6inches of course mine only went 5inches(did bring enough blocks):marchmellow: but i still had plenty of room to just drop the oil pick up with it, oh thos only hard part was the assholes who put my truck together welded the crossmember so I had to use a cutoff wheel to gind it down fuggers:dontknow: :marchmellow:
even with you giggle gas you only got me by a fender big daddy !u aint that far away :burnout:and i was bleeding at the time !!!!
Must be a fender off a 747, you really gonna bleed next time.:p :p :p :p
