he he he , like that did yawyoramsrt-10 said:I don't see any coils in there:dontknow:
You are sneaky little bugger aint cha:rock:Stinker said:he he he , like that did ya![]()
no they aint , but very close less than 50 lb spring rate differencewyoramsrt-10 said:Are the spring rates the same on the RC and QC?
Stinker said:no they aint , but very close less than 50 lb spring rate difference![]()
and yessir I am![]()
If you go this route, it would probably be easier to get some stock ones from stinker when he sells his next RC kit. Then he could ask the buyer if he wants to get rid of his stock springs.WA 2 FST said:Good to know. If I can find an RC'er who wants to part with his stock springs, I'll buy 'em.
WA 2 FST said:I would say that they would have to be. Just looking at the spring, I see 8 coils on the QC and 6 on the RC.
However, I like this idea in theory to get the truck a little lower in the front, but still easily aligned.
I also like the thought of the shackle and removing the "helper" spring. I don't tow and I won't haul anything over 500-700lbs at a time (and only then for short distances, and not often at all), so for me losing a little payload capacity isn't a big deal.
nobody I have sold the 2/5 drop to has told me they have had to lengthen the holes, so far everyone has had no problems aligning theresbigike said:2" drop you have problems aligning................ if you remove 1/4 to 1/2 a coil you will still be in the slot with room to play with............ It will ride EXACTLY the same it just wont be as high![]()
Stinker said:I little help![]()
if you want a 1x 2 drop ,
first all the shackles I know of only drop the rear approximatly 1.5 inches, this levels out the truck with it still having a small amount of rake
to go any lower with the rear you will have to do one of two things,
one remove a leaf from the pack, preferably the overload leaf, BUT this takes away the hauling capacity so be carefull
any lower and you will have to flip the axle
on the front if you want jsut 1 inch lower, do this find someone with a regular cab and buy the springs off them, they are a touch lower
cutting the springs is possible but it does change the spring rate of the spring, making it much softer rate than what it was.
DO NOT like OSO was saying, use ANY kind of heat, that will collapse the spring, and it will be useless.
looking at the pic you will see the one on the left is about an inch bigger or taller than the right
left qc right rc
the pics dont show it too well, but its only aobut 3/4 inch difference or about the size of a coil.
jeese and to think , I coulda done like others and jsut sold this to ya![]()
couple pounds not much, maybe 5 alltogetherYellow venom said:Just a curosity question,how much lighter would the two RC springs be compared to the two QC springs?
Stinker said:nobody I have sold the 2/5 drop to has told me they have had to lengthen the holes, so far everyone has had no problems aligning theres![]()
