Paxton Drive Belt
Venom10
Mesa.Arizona
I need to change my engine drive belt w/paxton sc. I can not find a belt the size i need. Was told by a local supplier it was paxton only,Does anyone have a answer for me.
my belt had broke and i had to get a new one and i have a paxton its a 7 rib belt and 112" long im pretty sure. the length is between 112 and 120" i cant remember exactly but its something like that
The belt length should be the last 3or4 numbers in the part # ie
7b1145. 7=7rib, 1145= 114.5". Anyway it will be clearly printed
on the belt.
i had to deal with it a while back but couldnt remember exactly what it was your probly right. i know it cost me close to 400 just to get a new belt on. 100 for belt 150 for labor plus 75 for a new tensioner that caused it.
Thanks Guys ,What i needed to know is where did you get the belt ? was it paxton only ?
I ended up with a longer belt for mine for the overdrive crank pulley, so I still have the original in new condition. PM me. I'll sell it cheap.;)
you can order it from an advanced auto parts or i got mine from gary cause he had em in stock but if you wait for it to be ordered about 60 or 70 dollars cheaper just for the part.
.................:elefant: Bingo! :elefant:
Quick
Thanks Guys the belt is paxton only. Ordered from DC performance problem solved.The belt is special made for paxton although in an emergency a 8 rib belt can be purchased and 8th rib cut off with razor nife the 8 rib comes in a 109.2 length paxton is 110 its tight but will work.
