I got a couple hours today to work on the truck. the last thing I need to put is the water jug for the intercooler system. Where do u guys have it mounted ? The instructions that come with the kit suck ass
I say put it where you want to, Mine was mounted on the out board side of the passenger side frame rail
Thanks guys. I made some brackets and mounted it behind the fog light. U can see it at all from the top. I'm going to have her driving by tonight
Wait, you are running it hard without a proper tune? If it's an email tune you should datalog to make sure everything is ok.
E, make sure the belt is tight as it will want to slip if not. Takes a bit of pressure! Check all of your connections as well for leaks. Make sure boost gauge has no leaks as well. If all above fails do you have the correct oil in it? Could be time for it to be rebuilt? Congrats on the newfound power though. How did the few pounds of boost feel?:burnout:
Santeen, is it weird to see your kit on other trucks now lol. I wish I could have gone ahead with this project but timing just wasn't right. Glad E bought it and got it put in as fast as he has.
It was almost on mine as well. . I had my six speed conversion I really needed to get done though. Glad you got it working E.
