Paxton Kit woes
You need a leak down test, and get a scope and inspect the top of the pistons...at least check out the plugs...look for a fine dust on them...I am worried about this engine...
The plugs have a tiny bit of fine dust, not enough to see without blowing on the plug. There must be a small amount round the deeper ceremic. The deeper ceramic is dark in color. The exposed is bright white. :mad: Though the plugs only have about 100 or less miles on them. They are in good condition no chips, cracks, ect.
I have looked down in to cyl 1. Its the only I can see, kinda, without a scope. Its looks ok. I would like to get a scope and look futher.
As far as the oil. I ran the engine for about 5 min this am with my hand over the dischage of the charger at various speeds with the pcv and dischage connections disconnected. Hand stayed dry. The paxton manual has 2 pcv valves on the drivers side pcv hose. They face opposite directions. I only have one. I am pretty certain the intake tube before supercharger is sucking oil from the valve covers, though I can't prove this until I put a catch can inline. Though this will only tell me the charger isn't leaking. It won't isolate blowby.
I am going to do dual fuel pumps and a catch can before I do much more driving. And no hard driving.:(
I haven't done a leak down test. I do have a leakdown tester. I guess if the lands are cracked that would be best way to determin this?
