Paxton Supercharger Specials/ Winter Specials
DC Performance said:
Hi all,
Thanks for the interest, here is the pricing you were asking about.
Prices for kits includes shipping in the US.
Ram SC kit (unpolished) List Price: 7499.00 DC Price: 6499.00
(polished) 7899.00 6899.00
Each kit comes with our technical support.
DC specific upgrade kit: $832
Blower plugs
Thermostat
Billet crankcase valve
PCM Program
Prices installed vary from RC to QC and what other mods you want. Each install comes with our upgrade kit, before and after dyno tests and custom tuning specific to your vehicle. A detialed estimate can be prepared for you. Most installs are in the 10-11k range with this discount.
So there is no option to work with the VEC? Only to custom tune your PCM? So I would have to have two PCMs to run a NOS program and a program with just the Paxton? Or is there another option?
You can use the VEC 2, but you will still need a pcm program to remove the wide open throttle timer. This will remove the "lean spikes" on wide open throttle. The VEC 2 cannot do this.
Some of you may remember my slow times at bandimere earlier this year when I ran Brokes nearly stock truck. After I installed the blower flash...removing the wide open throttle timer delay I nearly picked up a full second in the 1/4 mile. Best bang for the buck. From a standstill the truck has a hard time accelerating til the boost kicks in...after the flash and removal of the timer delay the bottom end wakes up quite a bit :burnout:
Okay I sent DC a PM and never got a response. I have had their Stage II PCM and flash since about August 2005. Does anyone know if the wide open throttle timers were removed on all of their flashes since the beginning or did they start doing that later? :dontknow:
So the PCM flash I got from Boomer (B&G) doesn't already do that? I haven't seen any lean spikes on my present tune. Is that only with the Paxton?
I also sent an email to your shop about a month ago for a Hemi flash. Haven't received a reply yet.
You gotta call....310-841-6996......
When sending an E-mail...I think you have to put a subject title in or it gets sent as Bulk.....:dontknow: ...
Dan and Tony are Johhny on the spot with the Telephone...
LOL, if I call them, I am sure to buy one. I am a sucker for mods. :D Modiholic. :star:
if you have the Xmetal Flash for a blower or NA, then the WOT timer is turned off
and no 12 step program to help......:D .....Dan spends alot of time talking me out of mods....give it a try.....:D
and you listen???? duuuhhhhhh?:dontknow: :dontknow:
Thanks Boomer.
was having problems with my truck, running like crap,popping through exhaust, kept throwing code 1391, one phone call to Dan he told me to check my split/second box maybe a little water got in there, I checked the box, it was like a small fish tank in there, dried it out, sprayed some wire dry in there, then gave it a nice trim and blowdry, truck has never idled smoother or run better, I called him back knowing they were closed just to leave Dan a thank you message on his voicemail, if you read this Dan thanks again problem solved, Dan really is the man.
Asher
Asher
They relocated my split second box....it is now under the rear seat.....:rock:
Can I still get this deal in April or May?l
I was just there today. Dan has very competitive prices. Call him for an appointment. He spent a lot of time with me in person going over several different options for several mods i'm doing from bone stock.
Brad
