just for starters I want build a bottom end for less then 10k, thats jsut the bottom end also, heads intake another story, but I got a damn good builder at the moment also, so build should last an hold up to almost anything, you can build them cheaper, but I look at it as a one time deal, go right the first time you dont have to do it a second.
but if you want to keep warranty
get an SCT tuner from torrie, best way to contact him is to email him at
[email protected] mention jts venom performance and you get a really good deal, plus he is one of the best around.
delete the cats, have him turn these off for ya and you shouldnt need simulators,also since you are in a half an half area of climate its up to you about the fan turning on at 170
get a cat back, loosens up some back pressure
throttle body seems to help
change the plugs, bingo, instant power
keep the fluids changed to synthetic
if you can afford a couple grand on headers, do so, they do yield hp.
a cold air intake , well they are more bling, but Justins is bar none the best around.
at that point you should have an easy 465+ rwhp
from there its picky little things such as coils, wires, porting, bling, but with most of that , with the exception of the cats, it would keep you mostly in warranty depending on your dealer.
going fast in a 10 starts at 10.............10k to be exact
