kickinassrt-10 said:Wow that looks intense....
I'm just doing a simple tap into my intake arm with one nozzle...
Did you install it yourself??
Sending you a PMspray said:Yea I done it yesterday evening, still have to wire it up
JeffBoyette said:Never seen the flexible lines on it..... Interesting
brassmonkey said:Way to much work imo but nice job. Would really look into doing hardlines tho.
Stinker said:they are working on your others now bud![]()
yessirspray said:Thanks Stinker, that is 4 lines 6in1\4 long with straight females on both ends -4an
some guys are having good success with spraying from the front of the intake (fatjack comes to mind on a 150 wet shot, jmb justin on a 175 shot,...), are you sure that was all that grenaded your motor ?? :dontknow:spray said:Not really that much work when I just took a 12k class on having to rebuild a motor for not using nitrous properly. To explain if you spray in the front of your intake the cylinders are not getting a certain amount, some get MORE some get less and that is not good
This was nowwhats' set-up...still holds the record :rock: :congrats: :rock:JeffBoyette said:Never seen the flexible lines on it..... Interesting
i've sprayed a 200 off a single nozzle in the intakemoparracing said:some guys are having good success with spraying from the front of the intake (fatjack comes to mind on a 150 wet shot, jmb justin on a 175 shot,...), are you sure that was all that grenaded your motor ?? :dontknow:
btw, pic of current setup is cool...... more pics when you're finished would be nice..... :rock:
yeah, but weren't you rebuilding your motor recently ?? :dontknow:Tooloe said:i've sprayed a 200 off a single nozzle in the intake
