You are also going to cut down swaybar end links, to make them function properly again.the swaybar needs to be parallel to the ground.
i have asked this before, what part of the sway bar needs to be parallel to the ground????:dontknow::dontknow:
The sway bar is essentially "U" shaped. The portions of the "U" that run from the front of the truck, towards the back of the truck, need to be parallel to the ground. Hope that makes sense.
In order to keep the information on this post accurate, I am posting a update. On my truck with polyurethane bushings 4 degrees down was to much. The driveshaft would bind at a coast on the interstate. I went back to 2 degrees down and it's all good now.:rock:
I am talking about pinion angle not swaybar. Every truck is different. But my truck with a 3 in block and poly bushings in the rear springs took 6 degrees of shim to get 2 degrees of negative pinion angle. Negative is down.
What do the poly bushings do to change the equation? Does it affect ride height or just flex more at launch?
We will get ya fixed up!!!
I put that shim in and now the vibration is worse.
