Well I am way over my head here...need some people with a lot more grease under their finger nails than I have.
But in the pictures below there seems to be some pretty strong evidence of a design flaw in our stock pistons...so take a moment to study the evidence as I see it.
Picture #1 is from what would be the drivers side of the engine with the pistons arrayed in correct sequence...and nothing looks wrong (I have removed the comprehension rings...)
Picture #2 is a closer look at pistons 1-5...
Picture #3 is a closer look at 6 - 10, still looking pretty good.
Now Picture # 4 is an over all shot of all ten pistons from the passenger side...
Picture # 5 and #6...Now there is some damage!
Note that all the ring land destruction is on the same side and begins at the same point...
If I were to reverse the piston domes for six more pictures you would see that the out side ring land on all ten pistons is damaged in the same way!
When my engine was disassembled every piston had cracks in the lands...once the pistons were pulled from the sleeves...the lands fell apart...and what you see is where I have pulled all of the cracked lands out after removing the compression rings.
I think that we see in my ten pistons that the outside of our pistons for some reason crack the lands...which can then lead to pieces falling out, and destroying engines...I may have been minutes away from Boom...
Any other conclusions from some of you wrenches???
