It is good now. FYI, the only noise I really had sounded about like a continuous "text vibrate" when turning slightly to the right or left. The left hub was definitely bad, but came out easy. The right was stuck and had a lot of crusty corrosion on the bottom half of the bearing opening. Used a sharp tool to scrape most of it down, then finished it up with a wire brush on cordless drill. Road test was great, noise was gone. I did find that some bushings are split and rotting. So, I guess that will be next.
