Power steering hose leaking
Discussion in 'General Discussion' started by EODSRT-10, May 28, 2010.
Car Parts
  1. EODSRT-10
    EODSRT-10 Full Access Member
    87
    Feb 17, 2007
    VA Beach VA
    Any one ever have the power steering hose that runs the fan start to leak right at the fitting coming out of the power steering pump? Any vendors on here carry that hose if I have to replace it? I would much rather support them than the dealer :D
  2. jsandlin
    jsandlin Full Access Member
    1,033
    Oct 29, 2008
    Katy, Texas
    yeah "stinker" JTS Venom Performance
  3. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    There is a plastic seal inside of that nut. It falls apart after a while.
    They are on national back order.
    It would be best to replace it completely with something else; as even if you waited for Dodge to make more new ones, they would fail again anyway.
    Mine leaked for 4 years. Now it doesn't and I don't have to smell ATF+4 in the cab anymore :D.
    Stinker has a kit.
  4. OnceBitten
    OnceBitten Full Access Member
    956
    Apr 1, 2008
    West Virginia
    STINKER!!! The stock replacement lines are crap!
  5. OnceBitten
    956
    Apr 1, 2008
    West Virginia
    You may want to consider doing the oil lines too!
  6. JTS VENOM PERFORMANCE
    JTS VENOM PERFORMANCE Active Member Preferred Vendor
    33,544
    SRT10 heaven
  7. popstoy
    popstoy Full Access Member
    191
    Mar 26, 2009
    toms river ,new jersy
    that washer is a must do.
  8. EODSRT-10
    87
    Feb 17, 2007
    VA Beach VA
    Awesome! I have the oil lines already, and will be getting in touch with stinker to order the lines but first I do have an all new problem. Last night I was racing a guy on the highway and when the tranny went to shift into 3rd, it just red-lined! After pulling over cause the transmission went out I had to get her towed home. There is no leaking and no grinding so I don't think the input shaft broke? I am thinking the torque converter went out? I had Dusty from HTS rebuild it and have put over 20K miles on it and no issues until now. Any other ideas of what it could be fellas?
  9. 05' Dodge
    05' Dodge New Member
    16
    Nov 19, 2009
    Cape Coral, Fl
    You think maybe the governor is getting stuck in the valve body? Or something like that.
  10. SilverSyde
    SilverSyde New Member
    10
    Nov 22, 2010
    France
    Hi,
    I had leaks on oil lines and power steering lines, I changed the oil hoses without problem, but I'm stuck on those steering. I cannot unscrew the fitting on the steering power pump :mad:
    There is very little access to the tools...
    How do you do ? Is there a special tool ?
  11. Midnight Runner
    Midnight Runner New Member Supporting Member
    7,442
    Mar 26, 2010
    Thats what I have, great lines.:rock:
  12. REPOMAN1
    REPOMAN1 Active Member Supporting Member
    2,589
    May 14, 2010
    EDGEWATER , NJ
    Yea I crows foot wrench
  13. SRT2SLOW
    4,372
    15
    Mar 27, 2010
    Green Cove Springs, FL
    That is where mines is leaking at
  14. 505'sFastestViper.
    505'sFastestViper. Full Access Member
    13,813
    Apr 26, 2007
    Farmington, N.M.
    does he pay you...or what?????
  15. viperhauler
    viperhauler Active Member Supporting Member
    18,943
    22
    Jul 27, 2008
    yep... and you can use a regular deep well to install the new an fitting to the pump itself...
  16. yellowfever#154
    yellowfever#154 Full Access Member
    3,258
    2
    Dec 14, 2007
    Lacombe, Alberta
    Haha, no doubt.
    Midnight, do your lines leak like mine do?
  17. SilverSyde
    10
    Nov 22, 2010
    France
    Thank you !
    I searched on google, because I've never seen tools like this in France, I do not even know if that exists here :dontknow:
    What is the size of the nut ?
  18. REPOMAN1
    2,589
    May 14, 2010
    EDGEWATER , NJ
    Craftsman made the one we used , I honestly don't know the size maybe someone who does will chime in . I don't know any other way to get to the fitting unless you use that tool though . Maybe you can order from sears
  19. Midnight Runner
    7,442
    Mar 26, 2010
    NOP. great lines speak for them selves. never had a problem with JTSVP..:rock::rock::rock::rock:
  20. REPOMAN1
    2,589
    May 14, 2010
    EDGEWATER , NJ
    Yea I agree I had them too very good quality
