Yesterday the truck started getting hard to turn intermittently. Temps are slowing creeping up as well. Fluid was low in the pump so I topped it off and the issues are still there. Seems like the A/C is not as cold at idle also. The odd thing is right before it started I hit a huge pot whole with the right front tire. I can't find any damage/leaks.
I thought maybe the belt is loose and I'm going to try and tightened the belt up later if I can figure it out.
This pump is less then a year old (I think) as it is the one Marty put on when the truck broke right after I picked the truck up last year. If the pump is failing would the pump work sometimes and be harder in reverse or would it just fail completely?
