BlackKnight
I have a 99 VW polo (european version of the jetta) but my question can refer to any car with power steering. When in park and I turn the wheel, I noticed that the pulley of the power steering pump will stop/lock up and then the belt squeaks b/c the pulley is no longer turning with the belt. This also happens whenever I am turning at low speeds.
Is this a sign that the belt is bad, or is the pump bad?
I also noticed that the belt doesn't look as tight as it could be; could a loose belt be the culprit?
Thanks in advance.
Thanks in advance.
