PVC?
Thomas J
Beaufort, SC
Is the hose coming from the drivers side valve cover the PVC?...Where does this hose run to? Had the intake off and now lost as to where it runs!:dontknow:
PVC
:D Might even finish one day
Yes, it is in the center, just past the throttle body.
Offtopic but does anybody know the hose diameter used on the JMB's oil catch can? Im moving mine to a different spot and need to pick up some hose.
I went out to the garage an measured my JMB catch can hose. It is 5/8" OD and 1/2" ID. It is very thin wall tubing. Go with the 1/2" ID and you should be good to go!
