What made you go with the AEM? What did you have before that? Right now I have a custom programmed PCM and a Vec II, the VEC II will also be controlling my meth injection. Just wondering if I should make the switch as well?
sprite said:Engine is going back in it Monday, transmission has been built, fuel system has been upgraded, all parts for the PTK kit are here, so definitely moving along.
Stinker, I just wanted to add a correction here. The VECII has nothing to do with the IAT sensor. It does fool the PCM with the engine timing by splicing into the crank sensor circuit. And depending on the application it will block the MAP sensor signal for boosted engines.Stinker said:With the AEM you can control everything, for one instance, the vec fools the computer by changing the air temp sensor readings which really and actually doesnt work, in reality the engine temp sensor is the one that needs adjusting.
Stinker said:Oh and Sprite didnt blow his, h bought the ame twin set up that I have and having it installed at Macedo, houldnt be too much longer, he allready has a forged bottom end i n his so shouldnt have any problems.
Ahha, good to know. Thanks!Stinker said:Hey Stingray not to start contraversy or anything BUT, there is a new version out that no-one but little ol me has , version s108 where sean has intergrated a new deal with the iat sensor, but your are correct the regular version did not have it. David thoughtthat would correct my problemSo if ya dont have the new corrected version sean can email it to ya, guess I shoulda stated that , oops!LOL
that info might be helpful to ya there Stingumray!![]()
Stinker said:and if you got a forged bottom end you dont need the meth at all, its just a bandaid
sprite said:Yes the STS kit killed #3 piston on the dyno and it seemed other pistons has some minor damage as well @ 4500 rpm with good A/F. Engine is rebuild with Diamond Forged Pistons 9:1, Cunningham Rods, other goodies, Suncoast has upgraded my transmission. I decided to not give the STS kit a second chance and instead go for a TT setup.
