I just bought a 05 QC SRT10, 52k miles, good condition, runs great. I noticed white/red residue on the passenger side of the motor after the 4hr drive home. No noticeable issues with the drive, ran around 200 degrees coolant temp the whole way home, engine oil temp around 205. The radiator cap appeared to be a bit old/loose so I replaced it and hoped it fixed it. It didn't, truck runs the same, electric fan works, isnt overheating. The coolant looks a bit brown and the reservoir is filled past the max fill line.
I wrapped a rag around the radiator cap just in case it started spraying again, it wouldnt spray my whole passenger side of the engine bay. Took me around 2 hours to clean it up. It only seems to do it when driven long distances. I bought a warranty when I bought the truck just in case, I don't want to use it unless I have to. Any thoughts?
I'm thinking about replacing the thermostat or at least testing it, maybe flushing the coolant system and replace it with fresh stuff. I'm also thinking about getting a coolant system pressure tester and see what's going on. Last resort would be to do a compression/leakdown test. Has this happened to any of you guys? I'd like to enjoy my new truck, hope it's not a pita.
