Otnielarencibia
Bump.......need it gone
Anyone want to fit smaller tires?
If they are sufficient for a regular Ram, they would be fine for daily work on a '10. They would also allow someone much better options for drag radial/slick choices.Maybe track only truck.
These are for the front, won't help your drag slick choice.
Maybe I knew that and was planning on running drag radials on the front.... Or maybe I should pay more attention before posting
The truck is not FWD
Well still 4 slicks would look killer anyway.
Actually, after running further calculations, I have decided that 5.88's would make my truck amazing on the street!Ahh, yeah you may need the extra grip up front when you switch to those awesome 5.13 gears
I do. Really bad.You just want in on the new trend im setting!!!
And that was rotating mass, the mass that matters most!I ran 17" 51lbs tire/wheel combo up front with a matching rim in the back with drag radials. 50#. Total weight savings was about 160#.
Psshhht. We all know that bling = more horsepower!The truck is not FWD
Wow. Just wow. Even I can't come up with a good response to this one. :vollkommenauf:My son has a cheby with 4 slicks on it......doesn't handle to well :dontknow:
Btw thanks for the free bump!
51lbs?! Hell I run a 15x3.5" wheel that weighs about 20lbs at the track, with stock brakes
Damn, thats pretty light.
Is that with the tire on or just the rim.
.......on weight reduced truck, because that's a lot of truck and not a lot of tire
