Rear lowering
BigRed460
Texas
I read somewhere that someone had lowered there rear an inch. All it was is some lowering blocks and a new set of u-bolts, I can't find some anywhere. Does anyone have a link?
1 inch gives it a rake look
2 inch makes it level
call your local 4wd shop and they can get you a set of blocks and u bolts.
now that is for a RC with the spring under
that was me.. inch block from rancho and new ubolts...thats it...this is level...2 inch on a reg cab would make the rear lower than the front
In the beginning I just lowered mine in the rear to level it out. It also improved the handling a little. I have since been Boomerized and have his whole kit for front and rear. It handles much better.
I still have my old block and u-bolts if you want them. Send me a PM and I will send them to you free of charge.
Just realize that it may take me a couple weeks. I work every day and don't have a lot of spare time, but then the price is right on the parts.
I'm having a local machine shop make some solid 1-1/2" aluminum blocks for mine as we speak. They should be ready tomorrow. I wanted it almost level with a tiny bit of rake. A local spring shop will bend the u-bolts tomorrow as well.:rock:
QUOTE]
Pm sent
I ORDERED MINE FROM SUMMIT RACING.
DROP SHACKLE.NOT MUCH.MAYBE 1 TO 1 1/2"
DOES LEVEL IT SOME.COULD USE A LITTLE MORE.
LOOKS BETTER. $60.00 +/-
