Reg cab lowering kit
allwayssideways
Hi guys
I read a lot about x-metal vs. ground force.
Please tell me that the difference between tem arent so big as all writtes in all posts.
Because I have orderd a Ground force for my 2006 Reg Cab.
I asked justin about a set QA1 shocks and I have allredy Caltracs on the truck.
Will this combination work well, or do I really have to change to the x-metal one?
Thanks from Switzeland:dontknow:
IMO, go with the x-metal lowering kit. It don't only lower your truck because it also improve the handling! I am planning to get the x-metal lowering kit soon.
I have the groundforce kit and have no problems. Will be installing QA1's in the next week or two.
I have the X-Metal on my 05, but the Groundforce will work just fine.
You will be happy with either.
Thank goodness you don't have a QC have heard many bad stories on lowering them.
The ground force inkl. springs, blocks shock (rear) all needed hardwear.
QC ? What shall I do with a QC in Switzerland, our roads are about 2.30m wheigt and the parkspaces are about 5.00m long so .....:D
all ya need on a rc is a set of front springs, rear blocks, u bolts, rear shocks, and a bump stop for the front
then if ya want the correct deal, get the sway bar links from Justin
jrgnd had a Ground Force and his was riding on the front bump stops !! the springs in a GF kit are NOT for a SRT,they are for 1/2 ton trucks with hemis.The V10 is just too heavy.Get a X-Metal or buy from Stinker .
Lettin the cat out;)
I am having some special springs made up for Hot Ram, after I get them and he ok's them, I will offer a special deal for the first orders, dont know yet what the price will be until they arrive, but will include the springs , bump stops, blocks, u bolts, and maybe shocks,or at least the option of shocks.
With the option too, of getting the qa1's from justin and his sway bar links to make a complete kit.(these are to be bought from justin)
the springs we are having made are about 1 1/4 shorter so should drop about 1 1/2 inches, and be about 10-20%stiffer on the spring rate.
It will be a few more weeks before i get them , then to Hot Ram, and await his results.
then I will send a set of QC springs to have done.
I assume the rate you mention is compared to stock? What are these springs rate like in comparison to what comes with the x-metal kit?
Yes those are compared to stock, and honestly I couldnt tell ya what x-metals spring rate is:dontknow:
I would assume they are atleast alittle bit stiffer too, but in al the posts I have seen here on the subject in the past 1 1/2 yrs. or so, I have never seen anyone ask or answer that.
well I have requested from the makers of the springs, a chart of the stock spring rate and of the new spring rate, hope that helps
Looking forward to the QC results. I gotta drop this dang 4x4 already
--wes
