I no certified in noting
I am just guessing and trying to remember stuff I have read on here :elefant: :elefant: :elefant:
Ouch.Stinker said:I forget , everyone here is a certified tech of 20+ years my bad
Incase your mech doesn't know. There are two bleeding valves on the front calipers.SnakeBite said:Sounds simple enough. I'll tell him to bleed it and see what that does.
Fixed.wyoramsrt-10 said:In case your mech doesn't know. There are two bleeding valves on EACH of the front calipers.
Kevan said:That's why you have FNG's on your race crew: to clean your wheels!
bee0912 said:How do i get that job and what does it pay!
I thought you were already doin that for Kevanbee0912 said:How do i get that job and what does it pay!
wyoramsrt-10 said:I don't think Brembo did ours. They do handle the other SRT models though from how I understand it.
Wow.FSTJACK said:Some of us have had enough experiance that we don't get out the manual and have to study it before doing a " simple" thing like changing out a set of pads or setting up a ring and pinion, or installing a new clutch with a scattershield, and dial indicating the true centerline of the crankshaft, to mate match with the bellhousing and transmission, using offset dowels.
Don't even bother to look this one up you won't find it in the Dodge shop manual, but a lot of us do things like this regularly.
We have done most of this happy crap so many times, we know how this shit works without going to the book for everything.
And beacuse we have done it a lot, we have made a lot of mistakes and we know what doesn't work.
There are a few of us that have been in the industry for most of our lives and have done this for a living.
Listen to the guys with real experiance not somebody that read the book last night and became an instant expert.
Yep what he said.Stinker said:Anytime you loose dust , unfortunatly you are gonna loose a bit of braking ability.
I would use nothing but performance friction pads , used them for years, and braking is outstanding.
but to your problem, take some 320 or 400 grit sandpaper, lightly sand the rotors both sides, then scuff off the pads to get the initial glaze off, then try reseating them, that will get you about as good as it gets.
wyoramsrt-10 said:I thought you were already doin that for Kevan
Halligan said:Call me crazy, but how long have you had the brakes? Did you seat the brakes properly?
I bought a set of the posi quiets. . . no, they're no where near as touchy as the stock ones, but they will still stop on a dime. I thought they were awful at first, but once I received the direction on how to properly break them in, it was only a matter of time before I received better braking power.
