screamindemon
So my Yellow Fever is leaking oil from one of the lines
and I'm going to try to change the leaky bastard myself. unless its gonna be a bitch(but it looks simple) any input would be GREAT!:rock:
So my Yellow Fever is leaking oil from one of the linesand I'm going to try to change the leaky bastard myself. unless its gonna be a bitch(but it looks simple) any input would be GREAT!:rock:
Where the oil lines go into the oil cooler, does it matter which line goes on top?
The stock ones should be marked on the block or cooler side i forget but one is the feed line the other is return. do one at a time and you wont have a problem. also when installing tonys like he said make sure u put the adapter the right way so that it seals if not your gonna have a huge mess of oil. Again, pretty easy job i would take the passenger tire off and fender well or guard to get to the lines easier and work comfortable.
Wassup guys! Can I replace my oil cooler lines w/o performing oil change? Just did it n don't wanna do it again. Any suggestion ? Thanks!!
