Reverse
StinkyLinky
Richmond, KY
I'm having increasingly difficult time pushing the shifter into reverse. Stock power, stock shifter. I recall that I could let it roll a little or go to another gear and then right into R, but both tricks seem to be working less and less frequently. And as I stated in the first line, it requires a push, not just the correct motion. I'm noticing those special days (less frequently) where it just goes into any gear like butter.
Any thoughts?
Flush the fluid as prev mentioned and if on occasion you have an issue slip it into 1st gear and it will go right into reverse.
Bleed, bleed and bleed some more always keeping reservoir filled as not to allow more air in lines. Could be towards end of clutch material as well.
I have the same issue. It'll work for a while but R gear in our trans is very weak for the weight and power the srt-10 has. Eventually you'll never be able to use reverse lol.
Mine is going in for a trans rebuild Friday. I'll post pictures.
