faslane505
So what is the max boost and power anyone has gotten out of a roe blower?
bigike said:10 ish........................ "JAMES"come on by you can look at mine, drink some evan williams and ride some quads!
PEACE BEATCH
Josh![]()
faslane505 said:dont they make a 14lb pulley?
SrtBrad said:If I remember right, Clint (Flchub) made 703hp to the rear tires on a stock engine that lasted less than 10K miles. I don't know what pound pulley he was using.
If you have forged internals and a Roe blower and add a 300 shot you would be in the 1000 HP club.![]()
:burnout: :burnout: Does Roe have an intercooler now?
blackviper said:The Roe blower should be good for 19lbs but it would have to be intercooled of course.
instead of an intercooler...couldnt you just use meth injection?
nycstev said:My Roe is a great little machine. Its really good for running around the blocks and going on road trips, which is basically what I do. If your looking to shatter world records then you should consider the turbos or Procharger
blackviper said:I would take a huge amount of meth to cool the charge and meth is pretty corrosive. I'm note sure I would want to run that much through the engine. It would probabably be harmful to everything. Lastly, if the pump were to fail it would go kaboom instantaneously.
