belgiumbarry
i did ask Roe about the water problems for the VEC3 and he promised me to provide a box for it :rock: :rock: instead of a 300 $ ? extension cable...
I love the idea of changing tunes on the fly. I can also use my no start card without going under the hood. That was worth every bit of the 300 bones.belgiumbarry said:i did ask Roe about the water problems for the VEC3 and he promised me to provide a box for it :rock: :rock: instead of a 300 $ ? extension cable...
94rt10ohio said:I am not worried about water, do not drive in the rain. Just thought it would be cool to be in the cab. Then if I need to change programs at a light I can
As for the PCM flash. Roe told me it is vital to have a stock PCM flash, or if you do get a PCM flash that fuel paramters and timing settings are kept stock. Only mod tranny parameters and fan kick on temp, or in my case, fan temp. They said the VEC 3 will not work correctly if the fuel and timing parameters are altered. Unsure about rev limiter, but I am guessing that is also only a PCM flash and not a VEC 3 item.
Damn, I do not have any racing shops near me to get some meth. Guess I am heading to Michigan.....
I plan to tear down my truck a week from Wednesday so I am ready to start installing everything when it shows up.
