labontecsi said:The drag style cage at the bottom of the page has higher door bars. I think swing out door bars are OK for IHRA and NHRA, I'll check the rulebook when I get home.
Scrambler1 said:My biggest gripe with a cage in our trucks, and why I will never have one, is that it would have to exit the back of the cab through the window and tie into the frame through the bed.
walbert said:Why not sort of redo the back window. Where the rollbar would exit the cab, make solid metal (same color of truck), then have a smaller rear window (width wise)?
Maybe someone could photochop? Would only be talking 8 inches or so per side. Maybe I will mess around when I get home.
OR there is always Plexi....
JMB Justin said:A roll cage with no helmet is alot more dangerous than no cage at all in most cases. Even stick on padding can only do so much to keep your head from bashing metal.
Justin
FerrariTruck said:yeah thats true, but with the cage in place it is very simple to add in a 5 point seat harness. All in all, a cage is meant for protection when you are in engaging in a activity that can lead to a loss of control...i.e. dom & his 950hp truck![]()
Don't need a rollcage on a Dyno :dontknow: :dontknow:505'sFastestViper. said:i dont think that he ever said that no one even knows if it is nhra approved
505'sFastestViper. said:nope sure don't......and i dont need oxygen after i go up a flight of stairs either
