Royal Purple
Its a great oil, I personally think if there would be any performance gains they would be minimal, probably more personal preference than anything, I myself like redline oil products, some on here use lucas, some amsoil, Just as long as you pick a good quality synthetic you should be fine.
oh man ! great question!
I think it would depend on your dealer, probably not unless you had an engine failure and they did an oil analysis to determine the problem and wanted to be a prick.
The best answer I could give you is to pm Stingray, he is a current tech at a dealer and could give you a better answer.
Stinker said:
Hey you know the difference between viscosity and shear strength stone boy?LOLOL:D
Bend over, I'll show ya both tensil strength AND viscosity.....;) :D
SD
No Royal Purple is not going to void your warranty as long as your using the right viscosity. You won't see a performance gain...either is good oil...
No performance gains with royal purple right? Then is there any advantage to using anything other then Mobile1?
yes you can get gains.
In a recent Super Chevy mag I think, they took a chevy dually and changed the oil, trans oil, and rear axle oil, gained around 10rwhp and 20 or so lbs of torque.
Mobil 1 is all around synthetic great oil.
Aftermarket oils such as Royal purpal, Red Line, and others have extra properties to help it be a tad slicker, they are just a tad more job specific.
I ONLY run Royal Purple because I was so impressed that my truck ran for 100 miles with NOTHING but the ROYAL PURPLE lube for break in .......that I only use their stuff now. Its expensive but seems to be very good.
Where can I get royal purple?
What Viscosity Please
Are you running their high performance oil or their racing oil? What viscosity are you running?
THANKS!
THANKS!
That was my next question. Which oil to get?
