How do I adjust the belt? If I put a wrench to the S/C pulley, I can turn it. It seems the belt needs adjustment. I can't believe that it would be that easy to turn. Shouldn't the friction of the belt make it almost impossible to turn?
as far as I know there is no "adjustment" the tensioner pully just keeps constant pressure with no adjustment...blackviper said:How do I adjust the belt? If I put a wrench to the S/C pulley, I can turn it. It seems the belt needs adjustment. I can't believe that it would be that easy to turn. Shouldn't the friction of the belt make it almost impossible to turn?
BigRed460 said:as far as I know there is no "adjustment" the tensioner pully just keeps constant pressure with no adjustment...
:dito: Mine will peak at 7ish psi... no slip after 2+ K on mine either... I do have a spare belt in the door pocket just in case though.b exxon said:watch the boost gauge, if it goes up to about 8psi right before you shift I wouldnt think its slipping, right?
