SrtBrad
Michel Productions
- Joined
- Feb 10, 2007
- Messages
- 12,873
- Reaction score
- 17
TNVIPER said:Great video.....:rock: :rock: :rock:
Fahrenheit said:I enjoyed that, IM READY TO GO TO THE TRACK NOW!!!!!!
I know it sounds like I lift, but we discussed that with the guy at the starting line and I think we determined that I was actually hitting the rev limiter each shift causing the pop sound or break in the rev range. Getting the LineLoc fixed this week.moparracing said:nice runs jerry. :rock:
you need a line lock. :burnout:
your power shifting, it sure sounds like you lift off the throttle during shifts. :dontknow:
Thanks for the video Brad, but I think Wifey wanted the shifting video in one piece by itself.:rock:SrtBrad said:Thanks Larry. I couldn't have done it without Jerry.:rock:
damn....... hope your engine continues to take hittin' the rev limiter like that.....:burnout:Trainman said:I was actually hitting the rev limiter each shift causing the pop sound or break in the rev range.
Trainman said:Thanks for the video Brad, but I think Wifey wanted the shifting video in one piece by itself.:rock:
51,000 miles and still does not use any oil between changes (3,000). Bedliner is out (with brackets it was 45 lbs), what you are seeing is a thin coat of spray in liner. Yes the M&H's seem to hook much better with the 5 second burnout as opposed to the 3 seconds recommended by M&H.:rock:moparracing said:damn....... hope your engine continues to take hittin' the rev limiter like that.....:burnout:
ya otta take out the bed liner too, bet that would save ~70lbs.![]()
ya seemed to hook better with a longer burnout on your m&h's, opposite what john @ m&h told us...... :dontknow:
Trainman said:51,000 miles and still does not use any oil between changes (3,000). Bedliner is out (with brackets it was 45 lbs), what you are seeing is a thin coat of spray in liner. Yes the M&H's seem to hook much better with the 5 second burnout as opposed to the 3 seconds recommended by M&H.:rock:
