Search more info of this Ram TT venom 1000
Domi
GERMANY
Hi
my name is Dominik
im new here in this forum , can you help me
i search here for more information about this Ram TT hennessey truck
because i found this truck in denmark and i want purchase it.
the old owner was from Florida boca raton
Have anyone see or know about this Ram TT .
is this 100% built from hennessey or is this car moded.
Dodge RAM 1500 SRT-10 HENNESEY 1000. 6gear, 9,0L Twin Turbo V10, 2 step Boost Control (low 800hp - high 1300hp) 1131rwhp
Link
Vehicles | Ecar
i haven't seen an RC hennessey truck...
but i've heard some ugly stories about his builds...
i'd pay $20k US for it...knowing i'd have to spend another $20k to make it right...that would be a good deal...
you might google hennessey's name and read up on some of his practices...
not sure who's it was, but if Hennessy touched it, ya better hope someone else went in behind him to "fix it"!!!:afraid:
Will
like he said, run from it unless it was gone over by someone else. Hennessey is a crook.
When hennessey Build a Engine like venom 1000 ,is everything inside forged parts or he leave stock engine. i have a part list from the car dealer. i can not look in to the engine.what are your experience , are the part realy inside ?
522 CID Stroker Motor
JE Forged Aluminum Pistons (9.0:1 compression ratio)
JE Pro Forged Steel Wrist Pins
Manley Pro Forged Steel Rods
ARP 2000 Rod Bolts & Head Bolts
Custom Machined Factory Crankshaft (exchange)
Polydyn Coated Rod Bearings
Computer Balanced Rotating Assembly
Twin Garrett Ball Bearing Turbos
Front Mounted Intercooler
Polished Stainless Steel Inlet Tubes
Custom Intercooler Hoses with T-Clamps
Stainless Steel Turbo Headers
Stainless Steel Turbo Down Pipes
External Wastegates
Upgraded Stainless Steel Exhaust System
Upgraded Hydraulic Lifters
Upgraded Fuel Injectors
Upgraded Fuel Pump & Fuel Lines
Upgraded Fuel Pressure Regulator
Centerforce Clutch Upgrade
They are most certainly not inside,, he likes to leave them stock and put big boost on them and have them blow up.. and they you go back for warranty and he tells you to F off..
External Wastegates
I've bought ram tt from hennessey
hello
I have buy a hennessey ram tt from denmark now i have make some changes and repair some parts
First checking the engine form Hennessey installed parts
Piston =JE
Rods = Manley
Crank and Rods bearings
Leakdown test
ARP bolt was istalled
Change sparks and Gap it
Change Injectors from 430cc to 630cc now i drive E85
Chane fuel lines Y-fitting 10an-to 2x8an to fuel-rails
Change fuel pressure from 30 to 75 psi
AEM EMS ECU for dodge viper installed
Installed 2 Airflow meter Bosch and connect to the AEM EMS to check the airflow for each turbo.
Hennessey forgot the oil restrictors and build wrong engine breather.
after some testing and race on autobahn i deleted the 5th-6th gear cluster.
i think the ram make about 1150hp at crank hp at 14psi ( hp= calculate the airflow from the airflow meters).
i make some pull from 60-125mph in 5,5 sec
here is a video fun with my friends Audi s2 700hp an another guys
the first run i thought the Audi doest accelerate That's why I no longer accelerates
second run is from 60mph to 165mph
[ame=http://www.youtube.com/watch?v=1j6eweTXU1Q]Turbomeyer S2 Limo on tour - YouTube[/ame]
now i need some parts like the 5th-6th gear cluster and another parts for the t56 ,can anyone help me to get this parts ?
i dont drive 1/4 mile it is possible to change the gear ration from RAM 5th 0.74 6th 0.5 to VIPER 5th 0.80 6th 0.63
Some pictures from t56
