I'm with ya 10000% on the safety part, and thus the reason I first started with the junction block.
It's 1/4" thick 6061 T-6 aluminum around all ports, giving it a bursting pressure of about 12 kabillion PSI (that's not a real number folks, but you get the idea). The lines will fail well before my junction block does.
With that said, the elbows in the front SS lines would then be the weakest point in the brake chain.
Reason #2: WHEN (not if), the brake lines need to be replaced, it will be 1000x easier for Goodridge to get a customer (or you) a 24" piece with a banjo on one end and a XXmm on the other; as opposed to a banjo on one end and a custom made 90º elbow on the other end.
Customer will only have to wait a couple of days for shipping of the line. They won't have to wait for the line to be custom built.
Also, this gives owners the opportunity to use lines from other manufacturers, if the need arises.
Reason #3: Few brake shops work with AN fittings. NPT and Metric are the standards. Any AN-type fittings would require a pro shop or a special order/custom built line.
On the original, the 'Popeye Pipe' is the 90º bend for the brake line on the drivers side.
With my junction block the 90º turn is built-in (just like the original, but cleaner), and thus the line needs to have a straight Metric connection.
I didn't design the junction block to work with the Hemi trucks. It just so happens that it would.
The last part of the puzzle for me is what type of 'connection' is needed inside the junction block ports. I tried to buy a junction block assy. from Dodge, but there's not even a part number for it!!!
Looks like mine will have to come apart and spend a day at the machine shop....unless anyone has one laying around?
I know that I can get the junction blocks made for only a few bucks more than whatever you're paying for the AN adapter and the angled bracket. It wouldn't be a dealer breaker.
I'm going to talk to the machine shop about adding a Viper logo (standard and/or Sneaky Pete) to the exposed face of the block. We could even do a "VTCOA" on it.
I'm sure JMB could do a wicked power coat on them for only a few duckets more, if colors are desired.
I ***LOVE*** the rear portion. I can't wait to see it on a truck with the TRW calipers. I'm *so* ready for that.
If you want to talk about this in person instead of in public, you're welcome to call.
I only ask that you give me a few hours to get some zzz's. I just got back from 745 miles in 11 hours with 0 tickets. I'm a little wiped out.
