04rcmoneypit
How did paint your headlights, and is there any chance of moisture getting inside?
i put them in the kitchen oven for 15 minutes then pry them open, i then taped the parts that were gonna stay chrome sanded and painted the rest,after the paint dry i put them back in the oven for about 5-10 minutes then i just put them back together, i used a hot glue gun around were the two parts meet as a precaution. and yes i guess if the two pieces don't seal right moisture can get inside.How did paint your headlights, and is there any chance of moisture getting inside?
Dallas:rock: :rock: :rock:where bouts in TX?
how did you paint the lights without loosing all the chrome. Mine just peeled off.
sorry, mr.anderson i don't know it was a given to me by a friend.where did you get this! I want one!
its really easy, just remove the four 10mm nuts on the bottom, pry the front of the scoop up (i used a flat tip screwdriver) there are four little clamps holding it then just pull it forward (wiggle it a little while pulling) then just put it back in reverse order.m really liking the hood scoop! Is it tough to remove?
What did you use to paint it?
