Spark plugs
Discussion in 'General Discussion' started by Baggie Austin, Dec 4, 2021.
Car Parts
  1. Baggie Austin
    Baggie Austin Full Access Member
    98
    40
    Sep 3, 2016
    Birmingham England
    Is there a nack to this
    None of my sockets seem to grip the plug
    Or are they a silly size I don't have ?
  2. Baggie Austin
    98
    40
    Sep 3, 2016
    Birmingham England
    It's ok
    Sorted.
    Removed those silly heat shields
    AMS3, Kiwi SRT10 and THEWELSHM like this.
  3. beastmode1
    beastmode1 Full Access Member
    565
    334
    Oct 2, 2014
    Denver, CO
    Did you go with the Champion spark plugs or NGK?
  4. butch2000
    butch2000 Member
    18
    27
    Mar 18, 2021
    I'd go with the NGK's , I have not had luck with the Chapions ,
  5. Modern Barbarian
    Modern Barbarian Active Member Supporting Member
    105
    132
    Sep 16, 2021
    I use the E3 plugs. It did make a minor difference on mine. gained about 2/10th a gallon on MPG.
  6. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    Indexing works.
    Point the electrode between 10 and 2 o'clock (toward the Intake Manifold) which is ideal.
    I don't like using washers for this.
    If the Electrode is pointing down, try another plug until it gets the orientation right (or close).
    Don't use thread lube as it works as a heat insulator.
    Use a torque wrench to complete as torqued values affect heat transfer.
    My 3 cents.
    AMS3 likes this.
