FaSt-RAM-716
im buying a stage 2 pmc w/flash and i wanted to know what would be the best place to get it from:rock:
No difference. Same thingy.AWDisuzu said:what's the difference between a stage 2 pcm and a stage 2 pcm with flash???
pm sent... thanks Paul.. you're a pleasure to work with too..amtrucker22 said:I got mine from TheMoparConnection. Robert is awesome to work with.
DC and I have the same flash, they have the best flash for these trucks IMHO. I always recommend a second PCM (on Quad Cabs), warranty not really the main reason but for towing. its not recommended you use the StageII for towing.Annu Kumar said:Dan At Dc Performance would be your best bet:rock: Get the Custom Pcm that way you can swap just incase you need warranty work and other sorts of things.
