starter trouble
bmxam962
Powder springs, Georgia
Has anyone replaced there starter and if so did you use oem or after market brand. Thanks for your info. Those with headers are you covering your starter with a heat sheild?
I have had no starter issues with my headers. I have not priced a started out, but I think I would stick with OEM.
Not being a smartass,but are you positive of the starter? What about loose connections, battery condition, starter relays, etc?
Just don't think I've ever heard of a starter going bad:dontknow:
Not that it's impossible, but seems to be a strong point of our engines actually :)
You can get lifetime warranty ones from Autozone and other stores I imagine though. They can also ensure its bad as well :)
Good luck and let us know what you find sir. :burnout:
yep. header heat killed mine.
shopped around & found an aftermarket unit a bit cheaper, seemed like it was $240 includin $20 core, kept the old one for spare. went with that AND installed heat wrap.
also found durin the trouble shootin that my clutch switch return springs had broken & stacked up & not always lettin the contacts touch. best i found for the switch was $60
i asked Tony if he had a heat sheild or offered hot rodded starters for our trucks. he said that he had started a starter heat sheild, but got but on the back burner & he was to take one of his spares & have it checked out to see if they could be "updated" a bit for extra performance, lol.
might want to get in touch with him & see if he got anything done with either
yes sir its starter new battery and cables. Works fine at cold start up after bring up to temp and driving shut it off will not start. I let it cool off and will start right up. Thanks for all the info.
No prob bro, I just hate seeing y'all spend unnecessary money if its not needed. I'm kinda like Geico, haha!
Sure sounds like a starter then. Crazy how its fine cold though:dontknow:
Of course it is electrical so they do funny stuff when they're tired, lol
I had the same problem with my L when I put the headers on. I didn't put the shield back on....didn't think it was a big deal till about a 6 months later. The big red cable coming from battery was fried! Only would start once it cooled down. As soon as it got even a little warm...no start till I let it cool again. Wasn't the starter though...it was JUST the cable. If you had a bad armature in your starter...then it would have intermitent starting whether cold or hot.
:top::top::top::top:
