Steering wheel lock question:
Django
Oceanside, CA. USA
My son has a C5 Corvette coupe. He was pulling out of his driveway this morning and (engine running) the steering wheel locked up.
The ignition switch on this model is in the dash, not the steering column....
It is a manual tranny....
He could not get the wheel to unlock, so he simply put it back into first and pulled back into the garage.....
Still the steering wheel is locked.....
Can anyone help....?
Thanks......
D
Does it have a tilt wheel,sometimes a bushing off of the tilt section will brake lose and jam in the threads on the wheel.
Thanks......
D
I doubt they use manual linkage to do this like in the old days, when it was relatively easy to fix shit. My guess is it's selonoid driven, and it's gonna be a take it to the dealer to get it fixed issue...but that's just a WAG...nothing on those cars, or most all cars for that matter, is easy to fix any more...
Thanks Earl,
Paul says the tilt is working fine... He jimmied that mutha and tilted it this way and that... But he still can't get it to unlock.....
Anyone else have this problem before...?
Other wise, it's AAA comin' in the AM with a flatbed......
D
if it was like 04-07 or some years like that I think there was a service recall for the ignition switch on some models, have him call the dealer with his vin and check, i know Joannes had to have the switch replaced for some recalll of that sorts
Could be, Steve-o..... :dontknow:
Thank You, bro....
D
here ya go D
http://forums.corvetteforum.com/c5-...lease-read-before-you-post-sticky-please.html
shortened
This is an attempt to compile all the Column Lock Information into one place. If there are errors, please contact me so I can make corrections. With all the recalls, there is a lot of confusion, questions, anxiety, and threads. Hopefully this will be helpful to our forum readers.
GM installed a Steering Column Lock mechanism on all 1997 - 2004 manual (MN6) cars and on 1997 to 2000 automatic (A4) cars
There is a GM recall for this problem on affected models and years
It is one of the most problematic issues that we C5 owners deal with
It can happen to you if you have a pre-2001 A4 without the recall or CLB installed OR any year MN6 or Z06 car without a CLB installed. Age or mileage makes no difference.
Low battery voltage seems to aggravate and sometimes cause column lock failures
Q What is the symptom of failure?
A Your steering wheel will not unlock and the DIC will display an error message "Service Steering Column Lock". Your owner's manual will instruct you to have your vehicle towed to the nearest GM dealer for repair.
Q What exactly causes this failure?
A When you insert your key into the ignition and turn it to the ON position, the BCM (Body Control Module) sends a command to your Column Lock Motor to "unlock" and then checks a status line to ensure that the steering column is unlocked. If it gets the wrong status, it will display an error message as mentioned above. It can be caused by ECL (Electronic Column Lock) mechanism failure and occasionally by low battery voltage, which sometimes confuses the BCM.
Q Can anything be done to unlock the steering column once it has locked up?
A Sometimes; turn the ignition OFF and REMOVE the key. Shock your lock motor actuator assembly by jerking the steering wheel against the stops. Re-insert your key and try again. Also, if your battery voltage is low, charge your battery or replace it.
Q If my battery is discharged and I jump it to get the engine started, the alternator is now charging shouldn't the column unlock?
A NO; The whole unlock sequence occurs before you ever turn your key to start your engine. If the battery is too low, you will probably have trouble with your column lock. Several folks have replaced their battery and the column lock problem has never occurred since.
Q Does this problem affect both A4’s and MN6 vehicles?
A Yes; however if you have 2001 or newer A4 car, the ECL lock plate has been replaced.
Q What years are affected?
A Pre-2001 A4 cars and all MN6 or MN12(Z06) cars.
Q Is there any solution for this problem?
A Yes; have the recall done if you have an A4 car or install a Column Lock Bypass (CLB) on MN6 & MN12 cars BEFORE the problem occurs. Once it fails, you may not be able to fix it without GM repair.
Q Where can I purchase a CLB?
A They are available from several of our forum vendors such as:
Thunder Racing and Corvettes of Houston
Q How much does a CLB cost?
A Typically about $49.95.
Q Is a CLB difficult to install?
A No; very simple (less than an hour) by following instructions. See this link for help: http://97vette.com/howto/columnlock/index.html
Q Can I build my own?
A Yes; if you have soldering skills and $20 in parts, you can build your own in about 1 hour. See this link for info: http://shelor.net/Z/CorvetteForum/Cscokd/
Q Are there other alternatives?
A Yes; there is a GM "Harness K" GM part no. 89023816 (was 88952427), which GM installs as part of its recall; it costs ~ $85.50.
Thanks, Tony....
Looks like it may be part of a recall.....
His is a '99 and that seems to fall within the perameters (pre 2001)
Thanks again, Stink......
You rule...
Tim
Django said:
Thanks, Tony....
You rule...
Tim
your quit welcome good sire:)
Tim, I wonder if a different key will "fix" the problem. Doesn't that key have a "chip" in the stalk?
Not that he mentioned, Jimi......
It's gettin' flatbedded into the dealer manana....
He said, "f*ck it"....
Maybe it'll be a free recall item....
Thanks alot to all..... the "boy wonder" thanks ya, too......
D
