REPOSTED:
The heads and cam were through a deal setup by Nathan and the savings were substantial. If you are looking for bang for the buck, there are cheaper ways to go than n.a. but n.a. is what I wanted. Besides it is a great future base for additional mods, s/c turbo or whatever.
I think Nathan is currently arranging the last group buy.
I just spoke with Jeff @ JM Cylinder Heads (the birthplace of the Strikers) and the heads are $6995 fully assembled, with the Jesel roller rockers and hardened push rods. You will have to add for valve cover spacers and a billet roller cam. The cam change is relatively cheap and helps take advantage of the heads. The cam choice I made was quite conservative but it is a heavy pig of a truck and I didn't want to change it enough to make it less than fully drivable.
The intake port takes a far more direct shot at the chamber than the stockers and requires an offset rocker. Plus the fact that the shaft mount Jesel gear won't fit under the stock covers. Plus gaskets, plugs, install costs if applicable, if you want a higher c.r., etc.
Tell your wife (if applicable); "Hey, it's time to change the antifreeze anyways, so I might as well buy the Strikers and cam now and do it all at once". It worked for me...
I did all of the install work myself because that is a good way to learn.
I left the manifolds alone as I think they work best that way for my application. I.O.W. in intentional port mismatch (intake ports are larger than the manifold ports, of course).
The tune was $699, I think, for the SCT handheld which includes "unlimited" tuning in that price. Find a good EXPERIENCED tuner that will work with you. [end]
I am still REALLY glad I went this route. The Strikers also have a fast-burn chamber similar to LS1s so you can up the static compression ratio (which is where some of the added power and mileage came from) and still run good pump gas. I went with a custom grind similar to the Viper coupe cam ground on a 114 and built for torque and it worked producing a WIDE torque band.
