Suspension
viperpowered505
I have a 2005 SRT-10 QC. I would like to know what lowering kit I can go with that is right for the money. I see there are a lot of kits from 400 to 1000.00. Need help on this one guys.
Give this guy a call.
http://shop.jtsvp.com/main.sc
thanks fellas:D
there is alot of different choices out there,
all of the kits our there, any kit ffor a regular hemi will work
ebach, mcgauhys, belltech, many others will work,
or you can jsut install shackles and remove a leaf from the rear leaf spring pack and put it completely level for very little cost.
mine now , here is an explanation of mine and why
the front springs the others use like I say is for a hemi truck, our trucks are not hemis.A spring for a hemi truck has a lighter spring rate and will let our trucks bounce on bumpy road conditions
therefor the springs I use are the correct spring rate and all for a viper truck, differnt engine and different suspension than a regular hemi.
the rear flip kit is a weld in kit, IT MUST BE WELDED, the problem with most is they are nto welded in but bolted in, with the hp of our trucks and the way most folks drive, a bolt in kit will eventually fail and rotate the rear axle causing driveshaft removal at possibly a bad time
now with mine you get replacement rear shocks as they drop too low to keep oem ones, but you retain the front shocks.My kti is xtremely low, so some rubbing on large dips or big bumps may occur, but hopefully rarely
but with that said, a kit for a hemi truck will fit the ram srt 10
but then, i bought a viper truck, not a hemi truck
Tony, you should add that the Mcgauphey's kit "ONLY FITS" lol it's not the right or a good kit by a long way. Stay away from that kit.....
it does bottom pretty badly, when you commin home girly girl?
this is an email one of our members got back from a suspension company, one of the best around
i jsut wanted everyone to know why I say the things I do since some think the "hemi" kits are made for our trucks
this is an email i got back from Eibach itself :
Hello ---------,
We do not offer a lowering kit for the SRT-10 Dodge Ram model. That model
was never tested and the coil springs that we offer for the front only are
for the standard RAM 1500 model. The SRT-10 is heavier in the front and
therefore would need a higher rated spring for it. Unfortunately we do not
have anything that will lower your truck properly.
Best regards,
Abel Garcia | Assistant Sales Manager
Eibach Springs, Inc. | 264 Mariah Circle | Corona, CA 92879-1751
