thanks fellas
there is alot of different choices out there,
all of the kits our there, any kit ffor a regular hemi will work
ebach, mcgauhys, belltech, many others will work,
or you can jsut install shackles and remove a leaf from the rear leaf spring pack and put it completely level for very little cost.
mine now , here is an explanation of mine and why
the front springs the others use like I say is for a hemi truck, our trucks are not hemis.A spring for a hemi truck has a lighter spring rate and will let our trucks bounce on bumpy road conditions
therefor the springs I use are the correct spring rate and all for a viper truck, differnt engine and different suspension than a regular hemi.
the rear flip kit is a weld in kit, IT MUST BE WELDED, the problem with most is they are nto welded in but bolted in, with the hp of our trucks and the way most folks drive, a bolt in kit will eventually fail and rotate the rear axle causing driveshaft removal at possibly a bad time
now with mine you get replacement rear shocks as they drop too low to keep oem ones, but you retain the front shocks.My kti is xtremely low, so some rubbing on large dips or big bumps may occur, but hopefully rarely
but with that said, a kit for a hemi truck will fit the ram srt 10
but then, i bought a viper truck, not a hemi truck
