Black1
I'm putting the suspension back on the '67 Vette after having all my bushings replaced with Polyurathane....
My question is:
Should I use Loctite on the 8 bolts (4 on each side) connecting the half-shafts to the hub assembly (half-shaft spindle flange)?
:dontknow:
...... When I took it apart, I found TWO of the 4 bolts on the passenger side were sheered off, and the rest were less than finger-tight!
I had my local shop remove the two broken bolts and check/clean the threads, so that is all set... I just don't want them coming out again.
There ARE "French Locks" that secure the bolts, but they obviously didn't do a good job of it....
Anyone have any insight, or advise on this?
TIA
My question is:
