This guy definitely loves to detail !
Maybe!!! That would be lucky for sure :D
Nope ! Frustration has taken its toll at the moment with the pressure washer ! Need a 1 cent o-ring , bought the gas , topped off the oil and fired it up only after pouring a little gas down the carb throat and using a squirt bottle to try and keep it running , loosened the float bowel and gas does leak out . So the carb has gas , is getting air to fire . Tried turning the mixture screw all the way in and back to where it was adjusted to . Then pulled the cord a few more tome and the rope handle snapped off .. I have some pull cord and installed it , pulled about 10 more time totals and the cord started shredding and the next pull will snap in half .. ugh ! Little studies one right after another frustrates the crap out of me especially when it cost money and time ! So I’m going to leave it be and come back another day .. Maybe this time I’ll hold my mouth right and Varoom everything will go smoothly .. if not then I guess I just buy a spray nozzle for the hose hahaha !
Oh boy that is very phuggin phrustrating fo sho!!! That kind of crap can almost ruin a good day!! I'm crossing fingers it works for you next try!!!
I’ll chill,out over those little stupids soon enough and get back on it .. I’m not going to spend much to get it running .. heck it sat most of its life anyway ..
So today I decided I’ll take the one tire off and give it a good detailing along with attempting to finally put on the new brake pads , clean up the inside of the wheel well .. problem ugh hahaha I’m a glutton for punishment the last 2 days .. I could not find my caliper piston competing tools hahaha so the pads didn’t get replaced yet .. but I did clean up the caliper , wheel and tire inside and out ..hand polished the outside of the wheel with Mcquires aluminum polish ( that stuff sucks hahaha ) but did a decent job polishing it . The caliper came out way better than expected :). See pics of the front right ( last pic at the bottom ) and the one I detailed .
The inner rim cleaned up but it’s obviously been mangled for a lack of a better word from the elements and brake dust .. Still it turned out better than I thought it would . I didn’t have any of that tire black crap I’ll never use , so I used what I always use and had , Armor all ! 3 more to go and then the Dakota :rolleyes:
WOW!! those look very nice! The caliper looks new and the wheels are rust free and shiny!
Nice!
If you've never tried a product called Never Dull it works super great on aluminum!! It's a wad type material that you pull off from the Wad material in the can and it will turn black as it removes the grime!
Nice!
I’ve never heard of Never dull .. but I will look into it , thanks .
I was pleasantly suprise the caliper turned out like it did ,, considering it’s the first time since they have ever been cleaned ..I will say the super clean defiantly takes the grease off things and loosens up other grunge ! Heck I need to get another gallon though as I keep testing it on everything .. even did some laundry in my kitchen sink and added a little with the laundry detergent .. made some real dirty water hahaha !
Laundry too! That's great for mechanics for sure!
Never Dull
http://www.nevrdull.com/page6.html
Says it good for cleaning auto carpets and upholstery .. but test a small spot before doing it disclaimer
That did make the caliper like amazing though!
Well editing and translating otta do it for sure! Hahahaha
Maybe proof reading will do it before editing and translating come into effect ,,, Ah hall no , that’s no fun
I try but good grief it changes everything i type anyways!
Me also .. when I type the word shit it always type the word shot .. it is also set up to censor certain words ..
Well lo and behold ,,, I found my caliper piston tools and my C- clamp …now we’re is my nut buster hahaha
