- Joined
- May 18, 2006
- Messages
- 35,441
- Reaction score
- 13,462
Power Washer coming to life soonWell lo and behold ,,, I found my caliper piston tools and my C- clamp …now we’re is my nut buster hahaha
Yes , soon whatever that means hahaha. Brakes first !Power Washer coming to life soon
Not sure what that meant hahahaha!Yes , soon whatever that means hahaha. Brakes first !
Cool .. have you used it on the 10’s wheels ? Is it safe for the finish to use and use regularly?And to think I was the ONLY person on Planet Earth still using Nev R Dull.
Lol! Good stuff!And to think I was the ONLY person on Planet Earth still using Nev R Dull.
I think you'll have better luck on a different finish but that wheel you did is very clean lookingCool .. have you used it on the 10’s wheels ? Is it safe for the finish to use and use regularly?
And i actually like the way it’s smells hahahaLol! Good stuff!
Yes it appears to have a caution about using on lacquer painted surfaces ..I think you'll have better luck on a different finish but that wheel you did is very clean looking![]()
Oh my!! Yes! That's what NEVR DULL does! You will be amazedThen I tested it on the ram viper fang center cap … made a heck of a difference .. comparison is both front wheels .. it does take some rubbing and getting into the depressions but was worth the effort of 3 minutes hahaha ! Got some on the wheel and wiped it off and appears it should not be a problem so once I get my wheels off and cleaned up and brakes changed .. who knows when that will happen , I don’t trust the jacks that come with any vehicles .. need my damn floor Jack fixed .. View attachment 65686 View attachment 65684 View attachment 65685
Oh no!!And i actually like the way it’s smells hahaha
As far as I know they’re polished from the factory .. maybe they have a clear coat , I don’t know … but the center cap has no coating and it polished up better than great
The 10s are polished no laquer right?
Since I’m bored ,, I decided to do more little tests of the NEVR DULL !
Appears to be a metal cleaner .. not as harsh as TARNEX .It works on Silver too and other metals
Some have used it on their tail pipes
Nice review of the products! The name REJEX - that's funny!!View attachment 65695 Since I’m bored ,, I decided to do more little tests of the NEVR DULL !
I did 1 section of the grill and left the dirty section above for the pic . Shows a good difference in the chrome ! Then I went ver it with RejeX . Which I also did the Dakota wheel , it looked a little dull after the NEVR DULL .. the RejeX seemed to help . NEVR I don’t recommend for painted surfaces at least what I tested it on . My headlights lenses are messed up so I used Maquires rubbing compound on them to try and remove the oxidation .. helped somewhat but will need a lot more elbow grease and hopefully I can restore them back to as good as new . Then put RejeX on the lenses for temporary protection .
I like the RejeX and got it from Sinker ( Tony ) at JTSVP years ago ! Bottle states it can be used on most anything ! Wheels to protect agains brake dust . View attachment 65691 View attachment 65692 View attachment 65693 View attachment 65694
