Throttle Body Spacer
why not drill & port your nitrous directly into the intake (like jmb does) ?:dontknow:
It was advised to spray prior to the SC, so that the N2O gets thouroghly distributed as it goes through the compressor. Give me a few days till the metal gets here, and I will have a prototype.
Be careful when cutting the aluminum. use a sharp carbide cutter and plenty of oil or soluble coolant. And most important take your time :burnout:
www.nitrousoutlet.com
My local Nitrous shop already has a few made for our intake...
last i heard they had a Viper intake just like mine in the shop doing a custom job on it.. i'll give them acall monday they don't have it on their web site yet
I made the template today. Now all I need is the aluminum flat bar to arrive.
How about two extras! When you mount the nitrous nozzles will you have to countersink the holes so the nozzle will reach all the way through?
I used a router with a duplicating bearing bit.
My nozzles are long enough to not need a counter sink.
As for the cables, I may need to make a bracket to move the cable hanger by the 1/2" that I am moving the TB. We will see.
I should be able to make a few more if mine turns out OK. I am waiting on the metal to arrive. I should have it in hand soon.
