shorty
Maybe I spoke too soon, what are the symptoms of a out of round tire?
Bouncing when you blow by the wind up cars from Japan.
Bouncing when you blow by the wind up cars from Japan.![]()
I have run Pirellis, Bridgestones, Toyos, Continentals and Nittos. The continentals were by far my favorite. Guess what? They are discontinued, like every other great tire.
From a slow go I start to hear a womp womp womp that seams to go faster as I accelerate and past 35 or so, it goes away.
Does it go away after you drive and warm up the tires? If so add some air pressure. If the tires are out of round you would generally notice it more at a higher speed. Sometimes it can almost feel like you threw a wheel weight.
I have still noticed it after 15 mins of driving. I'm gonna try to tighten the lugs and see if that helps. Air pressure is good.
Checking the lug nut torque with a torque wrench should be the first thing you do. Checking air pressure would be second. If you still have a problem remove all the wheels. Check the rear mounting surface & hub for corrosion. If you find any clean it off with a wire brush. Then coat everything with anti seize. Steel hubs & aluminum wheels don't play well together. It's called bimetallic corrosion. Lastly any good tire shop should have a tool to check the tire for run out. While the trucks on the lift have them check the front suspension for anything loose.
