TORQUE SPECS
Bone
GA
TORQUE
DESCRIPTION (N·m) (Ft. Lbs). (In. Lbs.)
Bolts-A/C Compressor Mounting 23 - 200
Bolts-A/C Compressor Bracket 23 - 200
Bolt-Camshaft Position Sensor 11 - 95
Bolts-Camshaft Sprocket 23 - 200
Bolts-Camshaft Thrust Plate 24 - 210
Bolts-Connecting Rod Cap 68 50 -
Bolts-Crankshaft Main Bearing Cap (Refer to CRANKSHAFT - INSTALLATION)
Nuts-Crankshaft Oil Scraper 23 - 200
Bolts-Crankshaft Pulley 23 - 200
Bolt-Crankshaft Vibration Damper 176 130 -
Bolts-Cylinder Head (Refer to CYLINDER HEAD - INSTALLATION)
Bolts/Studs-Cylinder Head Cover 11 - 95
Exhaust Manifold 23 - 200
Exhaust Pipe to Exhaust Manifold 34 25 -
Bolts-Engine Mount Bracket-to-Block 41 30 -
Nuts-Engine Mount Insulator 102 75 -
Bolts-Flywheel to Crankshaft 75 55 -
Bolts-Generator Mounting 41 30 -
Bolts-Intake Manifold 11 - 95
Bolts-Oil Cooler 5 - 40
Oil Cooler Line Fitting 68 50 -
Bolts-Oil Pan
1/4–20 11 - 95
5/16–18 23 - 200
Plug-Oil Pan Drain 34 25 -
Plug-Oil Pressure Relief Valve 34 25 -
Bolts-Oil Pump Cover 23 - 200
Oil Pump Pick-up Tube
Bolt 1/4–20 11 - 95
Nut 5/16–18 23 - 200
Oil Filter 18 - 160
Oil Pressure Sensor 8.5 - 75
Oil Temperature Sensor 8.5 - 75
Bolts-Power Steering Pump Mounting 23 - 200
Bolts-Rear Crankshaft Seal Retainer 11 - 95
Bolts-Rocker Arm 35 26 -
Spark Plugs 27 20 -
Bolts-Starter Mounting 41 30 -
Bolts-Throttle Body 11 - 95
Bolts-Timing Chain Cover 23 - 200
Bolts-Water Pump Mounting 11 - 95
once again thanks to Patrick V
thanks Bone :)
do we ever have to check/retorque the cylinder head bolts , mine has for example now about 20K miles....:dontknow:
THis is great Thanks .
So Headers how Much in Ft./Lbs - 23-200 ?
Thanks
Where can I find the cylinder head procedures? I have to retorque at least one head bolt, and not wanting to mess it up.
1-12 first then the letters
Install cylinder head bolts 1–12. Tighten cylinder head bolts 1–12 in the sequence shown in (Cylinder Head Bolt Tightening Sequence) using a two step torque sequence:First to 47 N·m (35 ft. lbs.).Second to 122 N·m (90 ft. lbs.).After cylinder head bolts 1–12 have been tightened to specifications, install and tighten cylinder head tappet gallery bolts A–H in sequence shown in (Cylinder Head Bolt Tightening Sequence) to 11 N·m (95 in. lbs.).
